Right Angle Spline Drive
bluesman0007
160
Have a need for a right angle drive. Input hollow spline shaft through, male shaft output. Consider a X-Y axis slide arrangement where the Y axis is driven by a ball screw and the X axis is driven by a spline shaft. This allows the X slide to move at any position on the Y axis. May sound a little crazy but I'm trying to have the drive motors in the same general location.
Thanks,
Dennis
SolidWorks 2013
Dell Precision T3500
Nvidia Quadro 2000
Dual Monitors
bluesman0007,
There are through-hole (no output shaft) worm drives out there. What gear ratio do you want?
I suggest a chat with a power transmission vendor.
JHG
