Rigid Body Reference Node - Can it be changed from step to step?
mbqueens
10
When defining a rigid body constraint, is it possible to change the rigid body reference node from step to step? I know that you can only define one reference point per part in the Part module but I can create many reference points in the Assembly.
In the first step, I would like to rotate the rigid body 1 degree about the first reference point and then rotate the rigid body about a different reference point in step 2.
Any advice would be greatly appreciated.
