oharag11
- Jun 18, 2015
- 42
I'm using SW Sim Pro and trying to run a modal analysis of a hanging frame structure. There are 3 faces that I would like to connect using a Rigid Connector because a semi rigid object will be attached to these faces using fasteners. When I enter into the Connectors - Rigid Connection setup there is a pull down for different connections. If I choose Rigid there are two selection boxes (one blue the other pink). If I hover over the blue it says - Faces for rigid connection, and the pink says - target. I tried looking for an example that mimics my setup, but the info is very generic without examples. So, I believe I would select the three faces that will "move together" due to the hanging mass - but what do I select for Target?
