RIO Files
Electoman
7
Does anyone know where I can find RIO (Relay Interface by OMICRON) files on the internet? I am specifically looking for the RIO file for a GE Multilin T60 transformer protection relay.
SEL, Siemens and ABB have these files available, but I cannot find any for the new (UR Family) GE relays.
Regards.
I forgot to add, this RIO file is to test the Transformer Differential function using the Omicron Test Set.
RIO files for GE multilin may be hard to find if they haven't collaberated with OMICRON. I think you will find it to be same for most ALSTOM/Areva relays.
But personally I don't see much of a problem because you can use the differental or the Advanced differential module in the OMICRON test Universe to test for any setting of any manufacturer's relay.
Just takes a little more effort to set up the test conditions but you end up knowing the relay better.
User forum at Omicron website have lots of RIO files
Thanks, Aakhrinaam. I ended up doing the RIO File myself last week. You are right about learning more in the process.
I wanted something to compare it to, but the test results obviously speak for itself.
Happy, testing...
