Spurs
- Nov 7, 2002
- 297
I have had a few instances where the SW2006 model that I created (using a cavity process) has what would visually best be described as a tear in the model. What I mean by this is that when the model is viewed from a certain orientation - say from the front plane, you can actally see background lighting through tears in the model. When you view the same plane from the opposite side, these tears or holes are not there, nor should they be.
I have been told by a machine shop that when they go to cnc cut the part, the model does not come in clean in the area of the tears.
Has anyone seen this sort of thing before and can help to tell me how to prevent it?
