SomethingStructural
- Oct 14, 2014
- 13
I've run into this problem before. I'm trying to model a W6x20 in plate. I modeled the flange using one large plate. I then tried to submesh it using the quad submesh tool. I want 1/2" square elements, so I told it to submesh using 12 elements along the 6" wide flange (okay, I actually did it as 2 3" wide elements and tried submeshing with 6 across the side, but it's the same thing). See the attached photo for the result. It's a 4' long piece, and it did the same thing along the side that I specified for 96 elements.
Has anyone run into this before? Does anyone have a solution?
Thanks.
Thanks.
