First, thanks to all that make these forums a fantastic resource.
I'm a fairly new user to 3D and Floor. My steel framed buildings typically have two types of roof/floor assemblies.
What is the best way to model these two types of floors with respect to program inputs:
Roof: 20 or 22 ga B-deck with insulation and EPDM above and the deck is fastened to bar joists and WF beams with a 36/4 or similar pattern.
Floor: 6 inch total thickness concrete on a 20 ga, 1 1/2" B-Lok "composite" metal deck.
I don't intend to use shear studs on my beams. I use quotes on composite because in Floor it appears that all references to composite is to the beam-slab composite action afforded by shear studs, even though the B-Lok is also composite...in its own way. Is this correct?
Thank you.
Thank you.
