I have noticed this several times in doing FEA in RISA. I graphically show the Von Mises stresses using the contours option on the screen and notice the highest stress indicated by colors. Then I look at the plate stresses in the spreadsheet output and sort max to min. The highest stress is much more than that shown on the screen and it's not a rounding issue. For example, my model graphically states the highest stress is around 37 ksi. The plate spreadsheet shows plates with over 41 ksi.
Even more specifically again for Von Mises, the graphical output will show colors indicating the stresses in a plate. The key at the top right indicates the stress values. Based on the color on specific plates, the stress could not be the stress indicated on the spreadsheet results for that plate. Is this typical? Am I misinterpreting the results?
On a different note, why do stresses seem to drop off at the last plate before an intersection. For example, I have modeled a wide flange with wheel loads for an underhung monorail trolley. As expected, the stresses increase from the load application point toward the web. However at the final flange plate element where the flange connects to the web, the stresses decrease somewhat. This would seem clearly wrong. I find similar things in other models like this occurring one plate element from perpendicular intersecting plates.
This is a very simple model so I'd be surprised to find out that I am doing something wrong, but maybe so. Is this a quirk of FEA modeling? Is this a RISA issue? Any help is appreciated.
