Hi Bill,
In my use of the term "average power", power referred to losses in the resistor. There was no component other than a resistor mentioned in the original post, so I thought that was clear the power referred to the resistor. Further it was stated "The average power is the resistance times the rms current squared" which defines exactly which average power we are talking about. But if you wanted to use the phrase "average resistive power", or "average power dissipated in resistor R1 during the interval (a,b)", those would certainly be more descriptive.
The use of the term average power is certainly correct (when the averaging interval is small compared to time constant as you say) although one could argue about how many qualifiers are required. In contrast, RMS losses and RMS power are simply not correct for this problem (heating of a resistor by a specified current). They do not mathematically describe anything related to this problem. There is a perfectly logical reason to compute rms of a current (to determine average power). There is no logical reason to compute rms of a power (rms horsepower of a motor is a special case where horsepower is used as a surrogate for current and so rms horsepower becomes relevant in that one special case).
Maybe a math example will help to illustrate that rms power is a completely different thing than average power:
Look at a current pulse train which is 1 for 25% of the cycle and and 0 for 75% of the cycle.
This pulse train is applied through a one-ohm resistor.
i.e.
i(t) = 1 for 0 < t < 0.25*T, i(t) = 0 for 0.25 < t < T, repeating at period T
R=1
i(t)^2 = 1 for 0 < t < 0.25*T, 0 for 0.25 < t < T
<i(t)^2> = 1/4
Irms = sqrt<i^2(t)> = 1/2
<p(t)> = <I^2*R> = Irms^2 * R = 1/4 [AVERAGE POWER IS 1/4]
p(t)= I(t)^2 * R
p(t)^2 = I(t)^4 * R^2
p(t)^2 = 1 for 0 < t < 0.25*T, i(t) = 0 for 0.25 < t < T
<p(t)^2> = 0.25
Prms = sqrt<p^2(t)> = 1/2 [RMS POWER IS 1/2]
So we see from this example Prms = 1/2 and Paverage = 1/4. They are two different things. Paverage is relevant since we can multiply it by a time to determine the total energy added over the time interval. Prms cannot be used in this manner and has very little practical application. That is why I object to the use of Prms. It is a different quantity from Paverage.
