Turn radii for the internal roadway are important for moving large equipment. This should be designed to allow to move equipment inside the substation without an outage or major rework.
In the US, for new important substations usually is designed to accommodate a 73.5 ft (22.40 m) trailer WB-67 or largest equipment. For curves and turns should wider to accommodate the long lengths of the trailer that are needed to haul power transformers, reactors, etc. The following are the minimum recommended general criteria:
a) 14 ft (4.3 m) minimum to avoid back out.
b) 56 ft (17 m) for 90o turn
c) 71 ft (21.6 m) to account for hauling equipment.
The trailer also should have the ability to travel along the perimeter and any primary roadway necessary for future structure or equipment deliveries. To facilitate the design and construction of the roadways, It is recommended to use of the trailer turning template to reflect that on the civil package.
