Robot drops as soon as the motor brake is disengaged
GunT
79
0
0
I have already submitted this post in another forum. I apologize for repeating it here.
We are an equipment manufacturer. We are using 2 axis Linear transfer for pick and place of the product. The vertical axis has brake motor and we are controlling using a PLC. Whenever we are disengaging the brake, to start the vertical motion, the robot is free falling for 1/4" before the controller kicks in.
We were thinking that gravity compensation should be able to solve this jerk in the motion. But we are unable to solve the problem. These are following components we are using:
Motor: Mitsubishi - HFKP43BK
Amplifier: Mistubishi - MR-J3-40B1
PLC: Mitsubishi - Q02CPU
Any help to resolve the problem would be greatly appreciated.
Not sufficient to have the controller on. Should probably start to drive the motor in the direction you desire for a short period of time to develop motor torque. Then release the brake.
Are you certain this is not a *backlash* issue? I've seen a situation before where the coupling between motor & driven element was loose, allowed a few degrees of motion before engaging.
TygerDawg
