Yagonyonok
- Apr 23, 2008
- 110
I am having problems with mice/rats chewing through wires. Our unit sits flush with ground level, and has several sealed, removable compartments. The wiring harness running between these compartments is being chewed through. Rigid conduit is not an option since we need to be able to disconnect the various components.
As for other pertinent information; the cables range from CAT5e cable to #6 AWG four conductor cables. The run lengths are 2-6ft, and space if very limited, so flexibility of the wire is important.
I know this is not a unique problem, but haven’t been able to find a feasible solution that fits our applications. Right now I’m looking for some sort of armored cable. The problem will be trying to transition from this to our water tight connectors.
Short of completely redesigning our entire system so that the mice can’t get, is there anything that you have used or could recommend?
Thanks in advance.
Engineering is the art of modelling materials we do not wholly understand, into shapes we cannot precisely analyse so as to withstand forces we cannot properly assess, in such a way that the public has no reason to suspect the extent of our ignorance.
-A R Dykes
Thanks in advance.
-A R Dykes
