Rollback in NX9.0 3
Karlis
79
Hi everyone,
Is there a faster way to perform a rollback in NX so that you don't have to suppress each and every feature by clicking a hundred check boxes? Like in SolidWorks, for instance, you can simply grab a thick line that is right below the last feature in the feature tree, and drag it up. Wherever you put this thick line, every feature below it gets suppressed. I would really like to figure out how to do this in NX. Thanks.
To add to what cowski suggested, select the LAST feature that you want to see in the model and all subsequent feature will be 'suppressed' (actually they are not really suppressed but rather the 'timestamp' has been moved to a point in model's 'history' prior to the rest of the features). When you're finished with whatever you're doing at that point in the model's 'history', simply select the LAST feature in the 'history' (or for that matter any of the inactive features) and once again press MB3 and select the 'Make Current Feature' option.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you, that was what I was looking for :)
Ctrl+Shift+ Home/End/L/R(arrow keys)
L/R (arrow keys) will roll up/down step by step.
Michael Fernando (CSWE)
Tool and Die Designer
Siemens NX V9.0 + PDW
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
