jkate
- Nov 5, 2011
- 66
I'm looking for some help to determine the size and quantity of stainless steel bolts for a flanged joint as shown in the attachment. The flange is for joining the head and body of a non-code pressure filter. The head and body flanges are rolled leg out from 2"x2"x3/8" 304L stainless steel angle and has an 75A durometer o-ring for sealing. the vessel internal pressure is 50 psi, hydrotest pressure of 65 psi. The vessel OD is 54" Any help or guidance would be greatly appreciated.
Thank you.
Thank you.
