zipcurse
- Feb 4, 2011
- 2
I am evaluating a medical product design that includes a number of stainless steel ball bearing that have no lubrication. To be clear, the manufacturers normal lubrication has been intentionally cleaned out. I do not fully understand the logic of this, other than to avoid any biocompatability issue.
The ball bearings are 10mm in diameter, ABEC-3, running at <5rpm, very low radial loading (<2% of static rating), no thrust load, and very short life requirements. My only real issue with the bearings is rolling resistance. I have found a number of tools for calculating the lubricated torsional resistance, but nothing for dry. What kind of difference can I expect?
Thank you in advance.
