reverbz
- Aug 20, 2024
- 54
Hey Guys,
I'm trying to add a wood roof to an existing cmu wall enclosure. The CMU wall is 8" wide and 6' tall. My initial idea was to add steel HSS columns along the top and weld a saddle to them For anchors I was going to add an epoxy anchor each side of ea. column. I've attached a sketch.
For what it's worth the roof isn't all that heavy, I can rely on the bond beam to span it between the verticals as long as I check it right? As long as it spans with the column in the middle I don't need grout directly below the posts? That was my initial thought so let me know if I'm incorrect. Do epoxy anchors seem like the best choice here or would you guys recommend a different fastener? Anything else you guys see as a potential issue with my idea?
Thank you!!
Thank you!!
