roof rafters - no ceiling
jonathanwilkins
47
I'm working on a framing plan for a customer - the house has a very large 12/12 pitch roof and much of the 2nd floor is located inside of it. The living room of the house, on the plans, shows a vault from the exterior walls going flat at the same height as the 2nd floor ceiling. The longest rafter span (to a king rafter) is ~21'. There is also no way to support the ridge as it is over the living room.
End result is I can't use an i-joist rafter because there is no where to support a structural ridge, conventional framing doesn't even come close to working b/c the lack of ceiling makes the rafters way out of span. I thought about designing the top plate as a beam but can't get it connected at the ends.
Any ideas?
Man, someone had a bad meeting with an Architect recently!!! (by the way, at our office we call them "A's"..can't even say the full word).
I've never seen someone get so pissy about a little misnomer.
Do you also get pissed when someone says "footer" instead of "footing"?
If this is common and accepted terminology in AU, the UK or other countriues, my appologies.
My point was not made in anger. If you construed that, you're wrong. I am a stickler though on using proper English as well as proper technical terminology for what I perceive is my profession. It was merely meant to educate. Take it as you will. No worries, and no offense intended.
Mike McCann
MMC Engineering
Not an accepted term in the UK, or not before I came here.
Apsix, I must have been stuck in Mid-Atlantic, I intended to write, "Sheeting Rails".
I thought we were just passing time, waiting for a sketch of the problem, especially with all of this ambiguous terminology floating around.
Michael.
Timing has a lot to do with the outcome of a rain dance.
Quoting a portion of the definition from the glossary of building terms which Mike introduced,
One of a series of structural members of a roof designed to support roof loads. The rafters of a flat roof are sometimes called roof joists.
Personally I would not call a roof joist on a flat roof a rafter. I would call it a joist, but if it can be called a rafter, then maybe floor joists can be called floor rafters.
Just kidding! I really don't find the term "roof rafter" to be all than offensive.
BA
Sorry I haven't posted a sketch, the roof is a hip roof...there is no gable end to post a ridge beam. That would be too easy. The main ridge terminates at a point over the vault...no where to post down.
I wound up not doing anything. The contractor is in an area where engineers aren't required & he "can make it work." Just thought an engineer could help him. I'm interested to see if I hear back from him.
Thanks for all the replies.
Post a sketch! We are not mind readers! You are not fulfilling your obligation, namely to clarify the problem so that we have a clear understanding of it. We need your input in order to provide intelligent responses. Otherwise, this whole thread will have been a waste of time. Move it!!!!!
BA
Use a steel cranked ridge beam.
And, post a sketch.
