DoubleStud
- Jul 6, 2022
- 491
Every building department here uses different guidelines on how to determine roof snow load. Some give you the roof snow load, some give you the ground snow load and you go ahead and add the appropriate factors. Some counties specifically tell you to use ground snow load with no reduction. Some counties give you an equation based on elevation to get the roof snow load (not ground snow load). You will end up getting roof snow load that is very different sometimes even though it is only a few miles a way and at same elevation.
There is one county in particular that requires us to use ASCE Hazard Tool. My question is regarding the Roof Slope Factor Cs. Often they install snow guard or snow fence on the top of the roof to prevent snow sliding down. Do you think I should basically ignore the Cs factor (follow the the solid line on the graph)? Just wondering why some building departments tell us to use flat roof snow load no matter what.
