YoungGunner
I was running my own calcs for a long ridge beam (30', 10ft of trib) and found that my roof dead weight was enough to nearly offset all the suction for components and cladding. The roof dead load is about 15psf normally and then you have the self weight of such a massive beam. This has me concerned in comparison with truss manufacturers whose girders always seem to have 1,000# or more of uplift. But then I got realizing that those truss manufacturers aren't using the entire tributary area in determining their GCp factors - they seem to use only the area of each truss, and then add those truss uplifts to the girder.
So my question is - if I'm designing the connections of my ridge beam to the support, do I use the entire tributary area of that connection for my GCp, or do I add up the uplifts of every individual rafter along the beam per their respective GCp and base it on that? Each will yield very different results.
