I have a large pre-eng building foundation to design, and the "provided" column uplift forces are quite high...95 kips. I am planning to drop the top of the footings and add piers
to obtain the needed additional dead load from overburden. That is a lot of expense, and I'm sure the contractor did not plan on interior column piers, etc.
The typical interior footing needs to be 8'x8' for supporting the SL + DL. Has anyone ever considered the floor slab to act as a net in tension to hold the footing down. I would need about a 25ftx25ft section of slab to be activated .... I can't imagine the wind uplift pulling the footing up enough to crack the slab.... any thoughts.
