wayniac3
- Jan 13, 2004
- 29
I am working on a house located in the coastal area Virginia. Typical loads include: 110 mph wind, 20 psf roof live/snow. The attached sketches show the framing of the garage which includes 2x10 rafters, 2x8 ceiling joists adn 2x4 stud walls all at 16" o.c.
The room over the garage vaulted ceiling is going to cause rafter thrust. However, the room is approximately 27' deep. This is a bit long for a ridge beam scenario. Would it be possible to use double 2x10 rafters and reduce the thrust as the rafters would have twice the section modulus to increase stiffness? Also, could I make use of the knee walls to dissapate some of the thrust? I would appreciate constructive comments and suggestions. Thank you.
