rotary deburring tool
grunt58
490
Any one know of a pneumatic deburring tool like this (see link) that isn't actuated by a hand lever? I'd like the same style but to acuate it via a solenoid valve signaled by a robot. The robot will present the part to a degating fixture. Google has not been helpfull.
Grant
Applications Engineer
SW2006 SP 3.4
IBM InteliStation Pro M
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1100
Sorry this is not SW related but there's lots of folks here who I value there opion and experience.
Grant
SW2006 SP 3.4
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
A more suitable forum might be the Mechanical engineering other topics Forum forum404
... but as a kluge workaround, you could wire or tape the handle closed & use an in line solenoid valve to supply the air.
[cheers]
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Yah thought of that type of stuff but would rather not do that.
Thanks I posted my question in that forum. Thought someone here might have seen or used something similar.
Grant
SW2006 SP 3.4
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
Rotozip uses 1/4" collets; I have used Foredom flex-shaft grinders in an industrial environment, but the collet was only 1/8". That was several years ago, and they may have some powerful enough to handle 1/4" collets.
Flores
SW06 SP4.0
I'd contact dynabrade and see what they have to say. They are very friendly and helpful, and may be able to custom make or modify an existing unit for you. I know they do lots of repair and customization right there in Buffalo, NY.
hth
