PittEng88
- Feb 14, 2015
- 90
Hi All,
Our company recently received a submittal for a segmental retaining wall, that will be approximately 10-12 feet in height. Typically these submittals are pretty straight forward. However, the design engineer decided to rotate the entire wall, including the foundation base, 5 degrees on top of the 5 degree rotation he had from offsetting the blocks (see attached). Also, his calculations do not reflect this rotation properly, he is still using the equations as if the wall were vertical.
Besides the fact that his calculations are incorrect, can the wall even be constructed like what he is showing? Has anyone else ever come across something like this before?
