We have a device which has a 400mm diameter drum rotating from 400-800 rpm. Inside the drum there is a water ring, which thickness varies depending on flow rate, drum rotational speed and pressure. We have measured the thickness of this ring (actually the air column) with a capacitive type sensor. We have had problems with this and would like to measure the thickness of the water ring by placing a measurement on the rotating drum. I have measured pressure on the drum with some success, but since the water ring has a different tangential speed than the rotating drum at different operating conditions, it has made it difficult.
Are there any suggestions on another measurement technique?
