WhatSpeedLimits
Automotive
I'm in the process of upgrading from cams with a duration of 268in/264ex to 272/272 and was wondering if by looking at the timing charts if anyone could give an idea of what they would expect to happen.
The cams are from the same manufaturer and same lift, just different durations. I made a pic of the charts overlayed so we could see the profile differences.
The intake cam (on the right) is hard to see since it is 'only' open 4 degrees longer (from 268 to 272) and appears to have the the time split evenly on both opening and closing (2 degrees each). It also appears to be mostly different in profile under 8mm of lift..after that the lines converge.
(yes I know it is hard to see at this size)
The exhaust cam on the other hand is gaining 8 degrees total (from 264 to 272) and it seems they put all of it on opening the exhaust sooner..with a little left after holding peak causing closing at a slower rate at first but ending up matching the 264 closing around the 6mm lift mark (from what my untrained eyes can see).
Overlap appears to be about 2 degrees more with the cause being earlier intake opening.
Here is the chart overlay-
