Round Pad Footing 2
Bailey_SE
Anyone know how to calculate soil pressure for a round pad footing with vertical load and overturning? I'm thinking of just converting the area to a square and using that formula.
Here's a document that one of the geotechs posted a very long time ago. It's very handy. Gives solutions for not only a circular footing, but also rectangular bi-axial bending footings. There's a small table in Fig. 6-14 that you may need to iterate, but it's pretty straightforward.
Enjoy!
 https://files.engineering.com/getfile.aspx?folder=31faf317-18b6-4101-bece-e6a90090f5f2&file=teng_-_Biaxial_Foundation_Loading.pdf
We used to do Octagon footings all the time back in the day. We always used and equivalent square. Based on area.
The square footing makes more sense. It's easier to build and all the bars are the same length.
If large... octagon is good... used them a few times... easier than bending formwork... it's harder to straighten out!
For a circular footing, wouldn’t you just calculate P/A +/- M/S? For M, you could calculate a single resultant. S=Pi*d^3/32. Not easy to construct, but easy to analyze, no?
la belle vie,
That formula will work until the eccentricity is outside of the kern. After that, you have a triangular shaped soil bearing profile underneath a circular segment - which makes for messy math to get to qmax.
That's right. I was a young buck at the time. But, that was the reason we were given.... that Octagons were so much cheaper to construct than round footings. It allowed the contractors to re-use formwork efficiently as well.
For me, the Bible of elastic solutions for geotechnical Engineers is Poulos and Davis's Elastic Solutions for Soil and Rock Mechanics. It presents it all!
You can access it here: - see chapter 3 and 5 for instance.
BigH,
I tried the link - it returned a 404 Not Found error.
I searched the site and found the "Books" area, but when I click on the link for Elastic Sol'ns, I get redirected to a page asking if I want to join USUCGER.
