Hi torhouse
take your motor:-
10.3*1000= 2*3.142*3000*torque/60
therefore torque from your motor rearranging the above will
equal =
10.3*1000*60/(2*3.142*3000) = 32.78 Nm
so your motor currently driving your blower produces a torque of 32.78Nm.
So your motor power is 10.3kw and produces a torque 32.78Nm
at 3000rpm, now if I decrease the motor speed the torque increases and if I increase the motor speed the torque produced decreases.
Torque is whats required depending on the load and in your case its the blower, so if you change to an engine and you
gear it to get the blower to 3000rpm make sure you have enough torque to drive it.
regards
desertfox
