RSLogix 500 Always asking for CD when starting Linx
RayfromIntech
34
It seems that every time I start the software an error message comes up. [Error 1706: No valid source could be found for product RsLogix 500 ......]
Also Every time every time RSLinx boots up. RSLogix 500 asks for to insert the CD to install some features. I followed the instructions but this problem is consistant.
Does anyone have Ideas on how to solve these issues?
Have you installed the activation file? It probably came on a 3-1/2 floppy unless you happened to get the new factory talk activation but I don't think that is an option yet on RsLogix 500
TW Controls -
The latest version of Logix over here has activation via the internet. No more holding a backup copy of the activation floppy...
image.php
Sometimes I only open my mouth to swap feet...
Try opening ms excel.
type a few characters in a cell and flie save.
close excel and try opening rslogix again
Or
right click on my computer
go to properties
then to the advanced tab
then to environment variables
add a system variable
the name will be CHECKDRIVES
and value will be C
Then value will = H
H is not a network drive is it?
After adding the CHECKDRIVES statement the pc must be re-booted.
Lastly, right click on my documents folder and make sure the target is h: if it is not then correct it.
If this does not fix the issue the go to microsoft website and download the microsoft clean-up utility. run it only on rs500. reboot. re-install
