structeng2
I have a question about rooftop unit nonstructural component forces and how they relate to building diaphragm forces.
Say I have an RTU that weighs 1000lb. It is spring isolated, resulting in an Fp ~= 2500lbs. I design the connections to the roof utilizing the Fp force (ASCE7 Ch. 13), but when I include the RTU in my building diaphragm design, do I lump the 1000lbs into the overall diaphragm weight (and then calculate diaph forces per Ch 12), or do I use the 2500lbs directly as an addition to the calculated diaphragm forces?
Thanks.
Thanks.
