tracetrimble
I'm looking for an FDA-approved bearing material with high abrasion resistance. This application is for the food industry, similar to a packing seal, subjected to low pressure (<5 psi) water-based product, up to 220ºF. I have tested virgin teflon and two grades of FDA reinforced PTFE, including Rulon-641 ($$$!). These materials are wearing too quickly, and surprisingly, the Rulon really didn't perform any better than virgin.
I beieve the PV is within limits, but is also difficult to control because the loader material is 40 duro flat silicone (non-linear modulus, and somewhat difficult to control size tolerances).
I am considering a new FDA-approved Nylatron material. I am aware of the water-absorption characteristics of nylons, but I believe I can live with the swelling in this case, if the wear rate is reduced. The other problem with harder materials like nylon is that the current design uses the PTFE as a gasket as well, so a harder material will need secondary static seals.
For an idea of similar designs, see and
TIA! Trace
TIA! Trace
