Is it possible to show that running two pumps (smaller) is cheaper than running one single centrifugal pumps. I believe the energy savings are better in running two smaller pumps (esp given process variability in a running plant) since they are able to handle this better than running a larger single pump and then throttling flow at the discharge to meet requirements. However, I would like to know if there is some way to show based on general calculations from pump performance curves that running two smaller pumps is more economical than a single pumps. I do understand reliability is a different story (2 pumps provide better reliability in case part of the flow is useful) compared to a single pump. However if 100% flow is required for a particular process than a single pump would be a better option.
In this case however I am trying to look at it from a cost stand point and I would assume it makes better sense to look at it further from the lifecycle costing stand point of the pump rather than just purchase cost.
