running catia v5 with i9 12950 16 core cpu and rtx 3000 and Catia performs like a snail 1
kiario
Automotive
Jun 12, 2023
10
while modelling catia v5 only use 2 cores to 100% and gpu usage is around 7%.
frame rate in modelling is around 5-10 fps. Its stuttering a lot.
I know v5 is not multi core friendly and it is therefore why i see so low gpu usage because cpu cant feed gpu with enough data.
Is there anything that can be done. Anyone have and tips to improve this?
Upgrading to V6 is not oan option says my company.
can you share the SR number plz ?
Eric N.
kiario said:
There are hundreds of catia users in my company and they all have the same issue
Please contact your VAR or DS on the subject. This should be fixed.
Posting in Eng-Tips is a good way to find solution but on this topic, an SR should provide a solution.
Eric N.
