Running multiple subroutines for analysis 1
yaston4
130
I am trying to find some advice on running multiple subroutines for an abaqus analysis.
Should each subroutine have a seperate file or should be subroutines be placed in the same .for file? How should the subroutines be structured within the subroutine. Thanks.
So is the following format correct... as I want to make sure my methodology is correct. As I can not find a standard for this. I appreciate any input. Thanks
Subroutine One(args)
CODING
Return
End Subroutine One
Subroutine Two(args)
CODING
Return
End Subroutine Two
END
your subroutine is correct, but you need one conditional that use the subroutine in every case that you need, for example
if (mat="mat1") then
subroutine One
else (mat="mat2")
subrotuine Two
endif
I use this form and this run...i hope can help you!
Thanks lanavi017,
Do you place this about the two subroutines? As when I run this with my input file, it seems that the subroutine fails. I would appreciate some advice on the structure.
e.g.
PROGRAM PROG1
subroutine One
else (mat="mat2")
subrotuine Two
endif
CODING
Return
End Subroutine One
CODING
Return
End Subroutine Two
END
Also can this be done without a conditional statement, i.e. I would like both subroutines to run throughout the analysis.
I would like join to discussion about multiply subroutine.
At the beginning we need to distinguish what kind of subroutine we want to use.
Is it abaqus subroutine (UDISP, UMAT, …) or is it user subroutine wrote to perform specific tasks?
For Abaqus subroutine we have following limitation:
1. each subroutine can be call only one time (all distinguish between different materials
must be perform inside abaqus subroutine with conditional statements (IF, SELECT CASE).
We can do it like this:
Code:
 subroutine UMAT(args)
if (cmname == ‘MAT1’) then
  code for mat1 …
else if (cmname == ‘MAT2’) then
  code for mat2 …
end if
end subroutine UMAT
We cannot do it like this:
Code:
  code for mat1
end if
end subroutine UMAT
  code for mat2
end if
end subroutine UMAT
Here is obvious error since FORTRAN does not allow us to have two subroutines with the same name.
2. we must not call one abaqus subroutine from another abaqus subroutine
Following source code is wrong, even FORTRAN compilator will not give us an error. Results for this combination are unpredictable.
Code:
call USDFLD(args)
end subroutine UMAT
subroutine USDFLD(args)
code for USDFLD
end subroutine USDFLD
Of course we can have more than one abaqus subroutine in one file.
Abaqus himself will call both subroutines.
Code:
code for UMAT
end subroutine UMAT
code for USDFLD
end subroutine USDFLD(args)
With user subroutines is easier, we do not have such limitation. We can define both internal and external subroutines.
Code:
if (cmname==’MAT1’) then
  call mySubMat1(args) ! call internal subroutine
else if (cmname==’MAT2’) then
  call mySubMat2(args) ! call external subroutine
end if
contains ! define internal subroutine
subroutine mySubMat1(args)
code for mySubMat1(args)
end subroutine mySubMat1
end subroutine UMAT
! define external subroutine
subroutine mySubMat2(args)
code for mySubMat2
end subroutine mySubMat2
One more thing I prefer use always internal user subroutine, I had one time problems with arguments passed into external subroutine with gfortran.
But the same source code worked well with Intel fortran. Perhaps it’s something with gfortran settings I do not know.
Bartosz
