handleman
Automotive
- Jan 7, 2005
- 3,411
I'm designing a part that's basically a large-ish (over 2" diameter) disk/cylinder with a small-ish (less than 1/8") concentric hole. Then the disk is cut such that it has a flat, sort of like a wrench flat. So the cylindrical surface is no longer complete. I want the hole to be concentric to the outside diameter of the truncated disk.
I may be splitting hairs here... I know that I could specify the hole as the datum and then control the runout of the outside diameter, but it seems to me that it would be difficult to fixture the part to truly inspect it that way due to the hole being so small relative to the large part. OTOH, if I specify the large OD as the datum and control runout of the hole, does that mean that the hole surface is sort of "undefined" in the area where there's no corresponding outside diameter datum?
Hope that makes sense...
