SpaciouS
- Jun 3, 2011
- 69
A couple of questions on Runout,
1) It is my understanding that Runout surfaces are not defined with basic dimensions, rather, Runout is simply a surface call-out with tolerances withing the limits of size of the indicated surface. Is that correct? This is somewhat confusing since Runout is not recognized as either Form, Profile, Orientation or Location, yet I see it used with basic dimensions all the time.
2) If a part only has 1 axis, an optical lens for example, and that axis is identified as datum -A-, can you use Runout for the surfaces that defines datum -A-, and reference datum -A-?
This is another scheme I often see and do not understand.
Sean
Sean
