Runtime error CATIA BOM Export using Macro
pieswt
9
Hello Friends,
I am trying to export "Bill of Material"(BOM) using Macro for CATProduct. (I recorded the macro and modified it as per my requirement).
The macro is working fine but sometimes I get runtime error as shown below on yellow highlighted line of code.
When I restart CATIA, the macro start working couple of times and then again same error.
Can someone help me avoid this error and make the macro more robust?
Below is my code:
Code:
Public Sub CATMain()
    Dim Template As String
    Template = "C:\temp\BOM.xls"
    Dim productDocument1 As ProductDocument
    Set productDocument1 = CATIA.ActiveDocument
    Dim product1 As Product
    Set product1 = productDocument1.Product
    Dim assemblyConvertor1 As AssemblyConvertor
    Set assemblyConvertor1 = product1.GetItem("BillOfMaterial")
    Dim arrayOfVariantOfBSTR1(4)
    arrayOfVariantOfBSTR1(0) = "Quantity"
    arrayOfVariantOfBSTR1(1) = "Part Number"
    arrayOfVariantOfBSTR1(2) = "Type"
    arrayOfVariantOfBSTR1(3) = "Nomenclature"
    arrayOfVariantOfBSTR1(4) = "Revision"
    Set assemblyConvertor1Variant = assemblyConvertor1
    assemblyConvertor1Variant.SetCurrentFormat arrayOfVariantOfBSTR1
    Dim arrayOfVariantOfBSTR2(1)
    arrayOfVariantOfBSTR2(0) = "Quantity"
    arrayOfVariantOfBSTR2(1) = "Part Number"
    assemblyConvertor1Variant.SetSecondaryFormat arrayOfVariantOfBSTR2
    [highlight #FCE94F]assemblyConvertor1.[Print] "XLS", Template, product1[/highlight]
    MsgBox "Bom Exported Successfully"
End Sub
I'm not sure if this will help, but I noticed it is different from the BOM code I am using.
Instead of
Code:
Try
Code:
Dim assemblyConvertor1 As CATBaseDispatch
Jeff
