I need help to specify burst pressure and burst temperature of rupture disk. Operating condition of system: nitrogen compressed gas thru dia. 1" tube vessel working pressure 4500 psi. compressed gas supply pressure 2500 psi @ ambient temperature, 400 cfm. outside temperature -40F to 140F. rupture disk to be installed outside. I am planning to use 2" rupture disk.
Thanks you!
Thanks you!
