S&C SMD-20 Power Fuses
CuriousElectron
187
Greetings,
Have any of you guys used SMD-20 fuses for protection of pad mounted, 25kVA XFMR? I think these fuses are typically used for protection of overhead distribution transformers, would it be kosher to use them for pad-mounts as well? I don't see any issues.
EE
doesn't pad mount tx already got fuse installed on the unit?
i think the SMD-20 can only be installed on a pole
