Krausen
- Jan 1, 2013
- 289
I'm looking into a resolution for machining down a girth flange face on a TEMA/Section VIII S&T exchanger where we've found some pitting on the shell flange face where it bolts to the tubesheet. We will be replacing the tubesheet & tube bundle with a new one but have concerns about the existing shell flange face due some existing pitting that we know exists. It's been a problematic flange joint for our team to seal historically.
Can anyone direct me to where I can find how much code allowable thickness I can machine off the shell flange face before I have to weld buildup to restore the flange face?
The problem with the weld buildup path is that the metallurgy will require us to PWHT & will severely impact our schedule if we have to do this. So the hope is to only have to machine down the flange face to remove the pitting & then bolt this exchanger back up with the new bundle.
The shell was originally designed with 1/8" corrosion allowance I know. There was no machining allowance ever designed into this shell flange face though.
Thank you in advance.
Tolerance is the virtue of the man without convictions -GK Chesterton
