electricpete
- May 4, 2001
- 16,774
This is a 13,200kv 8,000 hp motor.
The rotor has steel rings called shrink rings or retainign rings. From external view, they are outbooard of each copper endrings, but I assume the copper endrings also extend underneath these rings.
I know these rings provide a heat sink for the copper end rings. I also know they have a purpose to stabilize the position of the copper endring... but I'm not sure what forces they are countering (centrifugal force... thermal expansion of endring?)
Question 1- can you add to or clarify the function of these retaining rings.
We measured runout (TIR) of one of these retaining rings to be 0.057". The adjacent copper end ring and the other-end copper end ring and retaining ring all had TIR approx 0.010" or lower. Typical readings for these motors are 0.005" are less.
Question 2: What would cause high TIR? Does it need to be corrected (by machining)... or is rotor balancing enough? Is this ring typically steel that would be magnetic, or is it typically non-magnetic stainless steel? (yes I will try a magnet).
