waliq
- Jan 28, 2019
- 53
Hi all,
I have been looking into the materials for nozzle pipe and flange for a vessel intended for a low temperature applications of -40 Deg C
I found out that SA 333 Grade 6 can be used to min. temperature to a minimum temperature of -45 Deg C while SA 350 LF Cl. 1 can be used to a min. temperature of -46 Deg C
My understanding is that both of these materials come as impact tested (by supplier) and there is no need for further impact testing them for an application of -40 Deg C.
Further, if I use these materials, do I need to check in the box in nozzle dialog of PV elite that these materials are impact tested?? Since, if I do not check this box and use these materials, the report shows a min of -29 Deg C for Sa 333 grade 6 material. But, the min temperature it can go is -45 deg C.
Please tell me if I am doing anything wrong and failing to understand properly
