Dear All,
I am working on ASME section VIII div.2,
as per permissible material list in Annex-3A of ASME section VIII div.2 and table-5A section II part-d,
SA-350LF2 can be used for pressure vessel manufactured as per ASME section VIII div.2,
But problem is it is not mentioning which class can be used (i.e SA-350LF2.cl.1 or SA-350LF2.CL.2),
Can some one suggest me a way to find which class can be used,
so that i can fix the impact test temperature and what should i mention in TDC,
when I am selecting SA-350 LF2 for division-2 in design software it is taking -17°F as impact test temperature which is actually for class-2 but i couldn't find any relevant information which can prove the class that can be used.
