metman
Materials
- Feb 18, 2002
- 1,187
This is how a shim(spacer) was specified. I think the specifier probably meant "...or solution heat treated," since solution treating requires rapid cooling whereas normalizing -- at least with carbon steel or alloy steel --is air cooled. If 304 SS is air cooled from the annealing temperature, would it not be susceptible to sensitization?
Does AMS 5910 actually include some statement in reference to normalizing?? I do not presently have access to this SAE spec.
