missstructures
I have the soil properties set to "Compression Only" and all cases as linear/static - why am I still getting tension in the soil pressures?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
You must perform a nonlinear analysis. "Compression Only" is a contact type nonlinearity, so it does not work with linear analysis.
retired13 said:Is that the SAFE only feature or generic throughout the analytical programs? Then what I did (using other programs) was wrong then.
