DavAD
- Nov 20, 2017
- 8
Hi, (long read ahead - thanks for taking time to read)
I have obtained the Safe Load Tables from a local supplier for Precast Concrete Planks (Sample Attached)
with notes (attached).
I am new to using precast elements, and would like to ask the following, if possible;
1. What is your opinion on precast concrete planks used as transfer slabs i.e. used to roof over an open basement with 5/6 apartment floors above.
Do the concrete planks (with 100mm topping and steel mesh), transfer the Line loads from above efficiently (compared to in-situ concrete)
Basically I am opting for other solutions given that the span at basement level is circa 6m, so reinforced in-situ concrete would result in higher expenses due to
it being high in thickness (400/500mm)
2. When considering line loads falling on a particular slab (1 element of 1.2m width) do you consider the slab acting as one due to topping. Or do you consider each plank individually carrying loads falling direct on it? I will be doing a topping of 100mm with A252 mesh to ensure spread of load on planks.
3. When having a line load of say 300kn/m(unfactored as per notes provided) along the span (parallel), given that the safe load tables are in Kg/m^2, how would you go about changing from kn/m to Kg/m^2 (divide by width of plank?)
and when having say 300kn/m (unfactored) along the span (parallel) and an additional say 250kn/m (unfactored) against span (Perpendicular) , would you find the
moment of the combined loads and revert to a line load Kn/m, and use that as your load?
4. Lastly, the tables gives Shear in Tonnes/panel. Is it safe to say that if we have a shear force of 150KN (from combined loads) - the applied shear is 14 Tonnes?
THANKYOU, your replies are very much appreciated.
(once again apologies for multiple questions)
