BrianGar
Automotive
- Jul 8, 2009
- 833
Recently I got commissioned to make a batch of high end picture frames,
The frames consist of machined aluminium and cf, the frame sides being approx 40mm x 12mm thick in a 6xxx series alloy. The frame sides are not joined at each corner, but instead the entire frame is machined from one piece of plate.
I have/am allowed 3mm for glazing.
Given that these are to be shipped internationally Im a little stuck on what type of glass to go for, or what the safety standard is concerning this. Or, if there is one.
My main concern is, the glass breaking in transit, it will be around 400mm x 300mm.
My second main concern that probably should be my first, is the end user getting injured should it fall off the wall/t.top.
I looked into some type of perspex/acrylic but Im afraid that it could feel very cheap if tapped with a finger. Car pictures in dealer show rooms spring to mind, sometimes you can see waves in the plastic, but maybe they just use too thin a plastic.
Will 'plastic' cloud over time due to uv, or scratch easily from being cleaned/dusted.
Should I just go with glass and package very well(easy done) Im still left with end user possible injury.
Maybe Im just being too cautious, all my own frames seem to have what I call 'dagger glass'(ordinary) fitted.
Opinions?
Thanks folks,
Brian,
Opinions?
Thanks folks,
Brian,
