Hello all,
Can you please help or direct me to any proper grounding requirements for dealing with a 400VDC system, specifically for a motor control system.
So I've got a 400VDC brushless motor that needs powering, and I've purchased a AC/DC power supply to generate the 400VDC from 208VAC 3ph wall power. The output is isolated from earth (chassis) ground and I tap off of the output to a small DC/DC to generate isolated 28V for control power.
What I'm not sure of, are the safety requirements for dealing with this high voltage DC. Should I keep the power and return lines completely isolated from chassis?
The 28V power I'm sure eventually gets tied to chassis through a PC ground.
I was thinking maybe I should tie the 400VDC power and return lines to chassis through a large (>1Meg) resistor, in the event that if someone accidentally touches one of those live wires, the likelihood is they themselves are grounded and the current path is then limited through the resistor (400VDC/1Meg). Another concern is what happens if one of the high voltage lines ends up coming into contact with the it's chassis grounded enclosure?
Thank you!
Thank you!
