Hello All,
I am trying to understand what would be the best seal (or gasket or soft seat, you name it) material for a safety valve.
Here are the data:
Field of operation: Sterilizers autoclaves.
Fluid: Steam, 2.2-2.4 bar(G) @ Temp ~135°C.
Safety valve set pressure is 2.8 bar(G).
In addition, I would like to reduce simmering as much as possible.
I am currently have few options in mind: EPDM/PTFE/VITON.
But I would like to figure out what would be the best seal (or gasket or soft seat, you name it) material for the intended safety valve.
Here are the data:
