We recently conducted some salt spray tests and are coming back with some data we find confusing. 5 stainless steel fasteners were sent to be tested by a well respected labratory in PA and 2 seperate tests were conducted on 5 samples of each of the 5 parts. We already had the material certs on the parts from the factory. They were a 1/4 Flatwasher, 1/4 X 3 Truss Phillips Machine Screw, 10 X 3/4 Flat phillips Sheet Metal Screw, 1/4 X 1 Hex Bolt, and a 1/4 Nylon Lock Nuts. All of these parts were purchased as 18-8 but had material specifications that fell within the 304 stainless steel requirements, except the washer which checked to 303. The first test, which all passed, was to ASTM-B117-97. We then asked the lab to run the parts continously until they showed rust. This test was performed to AMS QQ-P-35. The test was halted at our request at 500 hours. The bolt, nut and flatwasher showed no attack at 500 hours. However, the machine screw only went 24 hours till light red rust appeared and the sheet metal screw went 72 hours. I believe this could be due to the crevices of the phillips drive, which allowed a buildup of agents that successfully attacked the chromium oxide barrier. Or it might be due to the cold heading process for manufacturing screws, which is notorius for leaving microscopic fractures, allowing pitting. Are either of these two theories legitimate?
Confused?
Confused?
