catenaryworks
I am trying to analyze a 3-hinge arch to find the buckling load. I have attached the SAP file here, which has the modeling done correctly. I suspect I am not doing to P-delta analysis correctly.
My objective is to apply equal value point loads at the two knees and the top ridge, starting with P1=P2=P3 =36 kips and trying to determine at what equal value load the arch would buckle. The answer should be P1=P2=P3 = 43.1 kips. Other checks can be:
1. At P1 (left knee) = P2 (at ridge) = P3 (right knee)=36 kips, the downward deflection at the ridge should be 1.8189 in.
1. At P1 = P2 = P3 =40 kips, the downward deflection at the ridge should be 3.1909 in.
May I ask if someone could take a look and tell me what is not being done correctly? Thanks.
